Rust on fenders?
exp500
Continuing on the spider injection thing if you have a fuel pressure test gauge hook straight to the fuel rail schrader valve and there’s a PSI range if memory serves you need 53 psi at the rail to fire the injectors so leaking fuel lines (rust zones) failing fuel pump or filter/ bad pump harness among other things may mis-diag a spider injector
60-66# per FSM.
exp500
I don’t know where you got that number but maybe that’s for wot
Long ago I linked you to FSM, and yet you continue.....
LordWayback
You just need 52-53 psi to run anything less is a problem I’ve heard from 52-63 from the GM service manual the guy had asked what the minimum fuel pressure was not the entire range
metal2forall
