Z55 Rear Susp Conversion - Awful noise/clunk when going over big speed bumps
Bedhead514
Atlanta
I recently removed worn out Z55 air shocks and original coil springs from my 07 Tahoe. Replaced with Moog 81069 springs, 4 new moog spring boots, and Suncore shock/spring combo. New springs and shocks raised the rear of the truck, now it sits at 38.5in on the drivers side and 39in on passenger side. I believe the rear sat approx 2-2.5in lower before the swap.
When going over taller speed bumps at more than just a crawl, I sometimes get a horrible creak/groan noise with a clunk from the rear end. It feels like the rear end/axel is moving forward/backward after coming down off the speed bump, rather than just up and down.
Any ideas on what can cause this play/movement in the rear end?
sway bar? did you change that also, either way sounds like the sway bar bushings need to be lubed.
wjburken
Eastern Iowa
Did you get your clunk/groan/creak issue resolved?
If so, was it your sway bar bushings like Doubelieve suggested?
It nice to see what finally solves folks issues incase it comes up again.
Cbrpilot2
