Yukon 2007 radio
Peyton Collins
I have a 2007 Yukon factory radio that all the sudden stopped working. There are were no lights going to the radio, no sound, couldn’t hear turn signals, and door chimes weren’t working. Then I pulled out the fuse from under the hood (which was a good fuse) and put it back in which seemed to work…. Temporarily then it started doing it again just to wake up to now a dead battery. Hooked the battery up to a tinkle charger for a day and it started right up. Any thoughts??
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
I asked Grok about your issue, using your words. I think that the response will be helpful to you.
This is a classic 2007 Yukon (GMT900) electrical issue involving the radio, chimes/turn signals, and a parasitic battery drain. The temporary fix from pulling/reinstalling the under-hood fuse is a very common symptom, and the dead battery after it reoccurred points strongly to something staying powered (or partially powered) when it shouldn’t.
Why the radio, turn signals, and door chimes all failed together​
On these trucks the radio generates the audible chimes and turn-signal clicks through the left front speaker. The Body Control Module (BCM) sends the requests to the radio over the serial data bus. When the radio loses power or communication, you lose the radio and those sounds. That matches your description exactly.
Most likely causes (in order of probability for your symptoms)​
  1. Amplifier staying awake / internal short (very common on these years)
    There is a specific GM TSB (09-08-44-018) for 2008–2009 Yukons/Tahoes with the premium speaker system (UQS or similar) that describes exactly this: no audio, dead battery from parasitic draw caused by an internal short in the amplifier that keeps it powered. The 2007 is close enough in platform that the same failure mode shows up frequently.
    Pulling the 30 A amplifier fuse (under-hood) often temporarily “resets” things, which matches what you did.
  2. Radio itself or its power/ground circuit
    The radio can fail internally or lose constant power / switched power / ground, causing the same no-lights/no-sound condition. Forum reports of identical symptoms (radio + blinkers/chimes dead after battery events or randomly) are common.
  3. BCM or communication glitch / RAP (Retained Accessory Power) issue
    The BCM controls power modes and tells the radio when to stay on or sleep. A flaky BCM, poor connection, or RAP logic problem can leave modules awake and drain the battery while also killing radio power/communication.
  4. Other possibilities
    • Bad or weak battery (even after charging it can have a weak cell that lets voltage sag and modules misbehave).
    • Corroded/loose battery cables or grounds.
    • Aftermarket accessories (if any) wired incorrectly.
    • Door module or other body module staying awake.
What to do next (practical steps)​
  1. Confirm the parasitic draw
    With everything off and doors closed (wait 20–45 minutes for modules to sleep), measure current between the negative battery post and cable.
    • Normal sleep draw is typically under ~50 mA (often 20–30 mA).
    • Anything consistently over ~100 mA is a problem.
  2. Isolate the circuit
    Pull fuses one at a time (or measure voltage drop across each fuse with a sensitive meter) while watching the draw. Focus on:
    • Under-hood: Radio fuse (usually 15 A), Amplifier fuse (30 A).
    • These are the ones people most often find related to the exact symptoms you described.
  3. Quick checks while you’re in there
    • Visually inspect and re-seat the radio and amp fuses (even if they “look” good).
    • Clean and tighten both battery terminals and the main ground straps.
    • If you have an aftermarket amp or radio, disconnect it temporarily and re-test the draw.
  4. If the amp fuse kills the draw
    The amplifier is the prime suspect. Replacement is the usual fix (check for a green dot on some updated units per the TSB logic). Location is typically under the rear of the center console / floor area on these trucks.
  5. If it’s the radio circuit
    Test for constant 12 V, switched 12 V, and good ground at the radio connector. A failing radio or poor connection is common.
  6. Battery health
    Have the battery load-tested. A marginal battery + even a small extra draw will leave you stranded the next morning.
Bottom line​
Your temporary fuse reset + subsequent dead battery is textbook for either the amplifier staying awake or the radio/BCM circuit not going to sleep properly. Start with the amp and radio fuses and a proper parasitic-draw test—that will usually pinpoint it without throwing parts at the truck.
If you can tell me whether it has the Bose/premium sound system, any aftermarket audio, or the exact fuse number you pulled, I can narrow it further. A shop with a good scan tool can also check for BCM/radio communication codes quickly.
thatboy_eddie
