Wrong turn signal switch/lever/wiring in 2009 Tahoe
Blk 09 LTZ
I bought a 2009 Tahoe that does not have a REAR window wiper/washer switch on the turn signal lever. And it also does not have the rear wiper connector taped on the wiring harness opposite the tow/haul connector. Obviously somewhere along the line someone made a change and didn’t carfax it. Anyway, I need to know what wiring harness to look for in order to wire in a different switch with the rear wiper control. I couldn’t find one on a couple parts sites or search engines. The switch with the rear wiper control is readily available. I just need the harness with ALL the plugs and jacks.
B
Blk 09 LTZ
He may be able to assist with making your needed cable. When he sees it, he will chime in.
Okay, thanks, but I found the part number online(25807858), so have one on order along with the new switch. Had to get the whole harness even though I just need the turn signal lever wiring, but I found one for just $50! I still can’t understand why someone would put a pickup truck switch and wiring into a nice Tahoe.....probably cost, what they had on hand, or wanted to get it done fast or something(let someone else worry about it). So now it will be done right....sure hope the rear wiper/washer works after all this!
felixmontiel
