Windsheild Spray too low - SOLVED
Sparky75013
North Dallas
I’m looking for some advice from other 2015–2020 Yukon/Yukon XL owners who may have experienced this problem.
I have a 2018 GMC Yukon XL, and both windshield washer nozzles spray way too low. The washer fluid only hits approximately the bottom 4 inches of the windshield and does not reach high enough to properly clean the rest of the glass. The pressure seems to be fine, it is just the angle they spray at.
From what I have been able to determine, the factory washer nozzles on this vehicle are not adjustable, so the typical method of using a pin or small tool to aim the nozzle higher does not apply.
Has anyone else experienced this problem, and if so, what did you do to correct it?
Did replacing the factory nozzles solve the problem? Has anyone found a different OEM or aftermarket nozzle that fits and provides a better spray pattern? Or did you find another way to get the factory nozzles to spray higher?
Both of my nozzles are spraying, they simply spray much too low.
I’d really appreciate hearing from anyone who has actually dealt with this on a Yukon, or Tahoe, of this generation and found a solution that worked.
Thanks!
dntnvme
Did replacing the factory nozzles solve the problem? Has anyone found a different OEM or aftermarket nozzle that fits and provides a better spray pattern? I’ve seen accessories for Kawasaki while searching for parts, but I’m specifically looking for something compatible with the Yukon. Or did you find another way to get the factory nozzles to spray higher?
Thanks!
If both nozzles have good pressure but spray consistently too low, I’d start by replacing the nozzles with new OEM ones. Check that they’re the correct part number and properly seated, since a nozzle that isn’t sitting correctly can change the spray angle. I’d also inspect the hood around the nozzle mounts for any distortion. If new OEM nozzles still spray too low, then I’d look for an aftermarket nozzle with an adjustable spray pattern specifically made for the 2015–2020 Yukon/Tahoe.
S
Sparky75013
North Dallas
Thank you!
Jetskier77
I miss the days where some vehicles had the squirters mounted on the wiper arms and they would do a much better job of covering the windshield with water. My Tahoe had the same problem as yours and I was able to improve it slightly by replacing the windshield cowl panel. My nozzles had become a little clogged over time and they were difficult to clean. The new panel included both nozzles and while the pattern is still not perfect, it is notably better than it was.
S
Sparky75013
North Dallas
How funny you say this! I just completed replacing that very same part. the old one was missing a lot of the moulding that sealed against the glass. Now, the new ones spray just fine. Thanks
I'm glad to read that your issue is resolved. Please add the word "FIXED" or "SOLVED" to your thread's title, to let others who are experiencing a similar issue know that this thread has an identified solution.
alexblagoev
