Window Wash Tank Protection or Move to Another Location?
gmartin1215
For you guys that have an aftermarket front bumper that exposes the window washer reservoir, what have you done to help protect it?
After I put my front bumper on, I don't like how much it hangs done and is exposed as much as it is.
I was thinking of maybe fabricating something out of sheet metal or plastic to wrap around it as one idea. Another idea is relocating it to a different part of the engine bay but that could be a big deal considering its shape. The third idea is to find a shallower tank maybe.
What ideas do you guys have, or have tried?
gmartin1215
gmartin1215
Mine is in the stock location and it has never been a problem.
Thanks @Tozan . Good to know. I may do something yet, though.
Hey, what fender flares do you have on your rig?
Also, your signature says you are using a Warn 9500. Have you ever wished you had a bigger winch for your set-up?
Tozan
Overlander
Yavapai Arizona
My flares are made by Bushwacker the fit and finish is very sub par and they had to be trimed to fit the bumpers. I would not recommend them.
The 9500 is rated a lot heavier than my rig. Plus I actually have never used to to get unstuck it has only been used to aid other people...
Swanbird11
I recently built a high clearance front bumper and removed the washer reservoir. I've got a secondary battery set up in my rig so I'm planning on fabing up an aluminum reservoir on the right side infront of the radiator/ next to the headlight area. If I remember the dimensions right I was planning on getting a 4" piece of round tubing 12" long and welding on a additional rectangle piece off to the left of it where the sensor and pumps will be mounted.
gmartin1215
gmartin1215
Would love to see what you come up with for the wash tank!
DefiantOne
