Will Yukon running boards fit on Tahoe?
WHITEOUT
Dont Hate-Appreciate
Phoenix
tried to do a search but came up with nothing, hope you guys can help. I have been looking for running boards locally to no avail. So I found some Yukon running boards locally for a great price, but not sure if they will work or not. So.....
Will Yukon running boards fit on my Tahoe? They are off a vehicle of the same year, so hoping they will work.
Poncherello
Yes, Tahoe and Yukon running boards are interchangeable so long as they are not off the XL
WHITEOUT
WHITEOUT
Phoenix
right on, thanks so much bro, appreciate the quick response.
Poncherello
Only thing you need to check is whether you need a mounting kit or need to drill holes to mount. Back in 1998 I had a Durango that I added OEM running boards to and I had to drill the hole in the frame in order to mount them. It seemed the factory only drilled the holes on vehicles that had the running board option. Not sure if GM is the same.
rockola1971
Indiana (formerly IL)
Yukon(non XL), Tahoe, Escalade of the same generation have the same chassis. Only difference between them is logos, trim package, interior options, what engine, Tcase comes factory instead as an option (ALL Yukon Denalis are AWD with a 6.0L of our generation for example).
Yukon XL is a Tahoe, Yukon, Escalade chassis stretched 14".
Yukon XL Wheelbase 130" Yukon, Tahoe, Escalade Wheelbase 116"
DefiantOne
