Since you will not be able to even look at the spiders that close till it is apart, I would order all that we have talked about and then return what you don't use. The ones that I have tore open have always looked nasty down in there because of the age. If it looks pretty clean with the age and miles of your rig, then may be ok to take a chance but I hate tearing all the way down again if I guess wrong. Plus, as you disassemble and then if make a decision to reuse the old, just the pressures and vibrations of the disassembly can make even good components be bad components that you will not realize till the restart. If you are keeping the rig, knowing what you took care of while in there will give you piece of mind.
About 2 years ago I had a water pump leak that resulted in a new water pump, new thermo housing, new thermo, new a/c serp belt and the new primary belt, new tensioners and new idlers, new fan clutch......all because of the water pump leak.
I bought the rig about 3.5 years ago. It runs like a top and the trans performs flawlessly and all interior controls work as they should. The only interior repair has been the typical driver's leather seat tear/rip/foam/seat pan repair. I also replaced one missing radio control dial knob that was not there when I bought it. I mean it when I say it that I would not be afraid to take off on any trip to any part of the great US of A in that Tahoe.
