Pretty hard to tell by the eyeball test. If you can get the XD model name, Tire Rack lists the offset with each style.
If you can’t get the model, maybe just do a search on TR using the vehicle and the brand filter for XD wheels only and see if you can pick out the wheel style, the offset will be listed with that wheel’s specs.
Thanks I’ll give that a try. It’s just the amount of poke I’d like on mine I think.
Looks about the same stance as my truck (maybe that one you posted is even more aggressive). Here’s what I’m running just to give you an idea:
17x8.5” 24mm offset
2” wheel spacers
= about -26mm offset.
So if my math is right, you have a 4" wider track than stock, is that right?
BTW, I like it.
Thanks!
Looks like the stock front track is 68.2”. I’ll have to get the measuring tape out a little later as my math skills are eluding me right now.![]()
I appreciate it.
I am looking at some AM wheels, 17" versus the 20" I have now, so I can air down a little when things get tight. The candidate wheels are zero offset, which I think will add 2" in track total (1" on both sides), which I can tolerate. In the winter, I am in a lot of muddy tracks, so too much track and I have a rolling mud pie within a short time.
Ok...measured it up from inside tire tread to outside tire tread for the front track width:
right at 72”
3.8” wider than stock.
So your math is way better than mine.
