thefrey
- Joined
- Feb 3, 2025
- Posts
- 436
- Reaction score
- 482
My auto lubing chassis seems to have had a self adjustment and now is working too well. AKA the oil leak I have seems to have gotten much worse recently. Changing oil filter did not fix it. Probably in the range of a quart every 1000 miles. I used to leak 1 quart every 5000 miles.
I have noticed on long drives, that I am actually getting droplets of oil on my back windshield. It is not bad enough to smoke when it hits the exhaust. I generally do not leak a lot of oil if the vehicle is sitting for awhile. The size of oil spot I leave is dependent upon how long of a drive I had...
The VLOM, valve cover gaskets, front timing cover, crank seal are all recently new, so the leak is coming from the rear of the engine somewhere.
The only things it could (should) be is either 1) oil cooler lines to oil pan, 2) oil pan gasket, or 3) rear main seal. Before I dye the oil, wanted to ask and see what the culprit most likely is out of all 3 of those before I start looking myself. Any insights?
