What happens if the Superior bypass kit is installed wrong?
poleec_hoe
I have a 2019 PPV I got with 98k on the dash, now at 107k. Took it to a local shop to have the transmission flushed yesterday, no issues beforehand but it was on my list to get done. I paid $337.95 incl tax for the flush. Dipstick shows red clear fluid so at least there's some fresh juice in there.
I looked under the truck and it does look like they cleaned the pan from the outside and a few of the bolts have torque marks. I don't think 7 years and ~100k miles would've survived some paint markers, so I'm inclined to think they cleaned out the pan too. The invoice doesn't mention filter, only labor + 14 qty of Valvoline Maxlife ATF for that line, but I read online it takes 6-7qt to fill so running it through once and filling it made sense to me.
I also asked them to install a trans thermostat bypass, bro said they already had the Superior kits on hand so I returned the PPE one I got from Amazon. I paid $254 for this installed. But again, there's some grease marks right where those two lines turn to so I figured it's done and drove off.
My problem is the trans fluid still shot up to 198F a little bit ago, in ~70F NW Indiana after driving ~5mi to get dinner. On the "stock" valve and old fluid it would get that high only over the summer in the highway. I thought these Superior kits were supposed to lower the temps.
Looking at the parts it seems like there is a way to install this kit wrong. Or they didn't do it and the new fluid is somehow different enough so it heats up and retains that heat quicker.
Obviously I'm going to go back in on Monday when they're open, but I'm just trying to understand what might have happened so I don't go in blazing guns.
you got took to the bank on that bypass
the thing cost's $20 and can be installed in 5-10 minutes without even lifting the vehicle
the bypass alone won't do a lot though
you can check it in your driveway to be sure it's installed and installed correctly
unbolt the plate, throw some plastic bags and rubber bands around the lines so they wont drip, nothing will come out of the transmission but a couple dripples of fluid
so put a big piece of cardboard under where you are working.
P
poleec_hoe
I part-crawled under the truck today but I'm going to blame the ppv chassis being lower instead of me being leisurely proportioned. Def need ramps or jack+stands to actually replace.
But in the meantime I did grab some photos. Looks like they actually did it, just put it in wrong most likely. Otherwise there wouldn't be leaks on the driveshaft is my thought.
Going to the shop tomorrow to have them fix it. I'm very annoyed but I'm going to fight this out with those idiots tomorrow first, I ordered a new kit anyway I'm probably still going to put it in next weekend regardless.
I’m taking some leaps here, but they might not have installed it wrong. I would say either they didn’t install it at all and the original thermostat is still opening as designed, or you actually don’t have the external cooler and it’s just circulating through the radiator exchanger. I was thinking that some of these trucks only came with the radiator “cooler”. I could be wrong on this, so take it for what it’s worth.
P
poleec_hoe
I took it back to the shop today and "turns out" the heater outlet hose is leaking, not the transmission. The guy was so proud to tell me how "one hose" broke and they replaced it free of charge on Friday too. It's the heater inlet hose...
Basically they messed up both of the heater inlet/outlet hoses, probably decided the outlet was good enough to be slapped out the shop and only replaced the inlet on their dime (car had no leaks prior to Friday btw). They also had the audacity to quote me $543 to replace the outlet hose. Sent me a link to leave them a Google review too, lmao.
Later at work a coworker confirmed it's more coolant that's leaking than ATF, and said that might be the reason the trans fluid temperature is messy too. So I ordered a GM genuine outlet hose for $40, plus a new T piece and when they arrive tomorrow I'm going to replace it.
Never going to that shop again, the "manager" kept on saying "I don't design them, build them, or buy them, I just fix them" too what a piece of work.
All of this to say: I still don't know if they actually installed the bypass, or did any other work than coil packs + new ATF for $3k. My plan is to fix the outlet hose + T piece, keep checking trans fluid temps.
If anyone has a shop recommendation in NW Indiana, please let me know.
P
poleec_hoe
I forgot I had an IR camera, so went to look. With the engine running, 8 degree F increase in trans temps (145 after being parked for an hour, to 153), and both coolant lines are blue and cold. The valve body meanwhile was orange.
Which confirms: these idiots actually installed this wrong, and/or somehow blocked the thermostat body. Instead of doubting themselves they decided to present a $543 unrelated repair.
alexblagoev
