Slow5.0
Missouri
Swapped Xenon Depot PSW26W 6000k for Morimoto XB sealed LED foglights and 5202 to PSW26W adapter harness. Yes Xenon Depot were brighter but Morimoto looks nice with black housing and its just foglight , not low beam
Before and after
Xenon Depot
Morimoto XB
pwtr02ss
Tennessee
What are you guys cleaning the "stainless" part of the roof rack on the Denali? Mine is looking very splotchy
ReaperHWK
Just got the Tahoe back from the body shop after someone crashed into the door and front fender. 4K later it’s fixed. Had to bring it back once because they put the Tahoe badging on crooked and I wasnt happy with the amount of orange peel. Looks OK now after they wet sanded with 3000 grit and polished it up.
Cody W
Massachusetts
I wish there was an good way to mount an Onx6 on my Suburban. Was that a custom bracket? How do you like the performance?
Rough Country sells a light bar and bracket set for the GMC Sierra. If you call their customer support you can order the brackets separately. You need to drill some additional holes in the plastic support piece for the grille shutters. Also needed to file down some nylon spacers from the hardware store since the light bar from RC is slightly wider than the onx6. Light output is awesome. The lens puts the light right where you need it
LT1ZOB
How'd it tow with your C7 back there? I'm going to have to tow my Camaro on a long haul soon should be like 5500-6000lbs including trailer that I'll be pulling.
Also, did you see the youtuber StreetSpeed717 there with his black C7 ZR1?
I’ve got about 11k miles on this trailer. My setup is about 5,200 lbs (the trailer is about 1,800 lbs). Loaded properly, you won’t know it’s there. Couple inches this way or that, and you feel your load working against you, so I recommend finding your specific load’s “happy place” on the trailer before the long haul. I also have a camaro and have towed it many times. You shouldn’t have any concerns. And yes, hung out with Mike and Shane at the Inshane tent a bit. Shane did some custom work for a buddy’s C8 recently.
kwhaleys
