dunbar_john
ok so i installed my rear 2/3 McGaughy's lowering kit for my 2004 z71 tahoe but as i was lowering the truck the left rear spring was loose and the right rear spring wasn't. so i figured that when i put the tires back on and put the truck back on the ground the spring would tight up. So it did, but my problem is that the left rear sits lower than the right rear. could it be cause the spring isnt cemented all the way with the factory rubber piece atop the spring?! here are some pictures if that might help.
