SOLVED: Water Leak?
Meccanoble
Georgia
When it rains, I find a little puddle on the driver floor mat. I can also catch drips coming from the a pillar if it rains bad enough while I'm in car. I think its related to some window rubber. Just wondering what to buy and how to install? This is only on driver side.
There is a drain (or two) in the frame holding the moon roof assembly that diverts any water to the outside (underneath) the truck that may accidently pass through the moon roof seal . Sometimes, these drains become clogged, and then the water must find another path, usually on 5the inside of the truck. Check out the status of these drain(s).
Foggy
KS
And sometimes those drain tubes come apart at the connections... This is really common
on GM cars (and others) since the water drains down by the A Pillars
M
Meccanoble
Georgia
Thanks for the feedback guys, where are these drain holes or common points of failure?
M
Meccanoble
Georgia
Finally took time to look into this and that is EXACTLY what happened. Had to remove sun visor and a pillar which gave enough access to see the failure. Added a rubber hose to secure connection and now all is well. THANK YOU!
Foggy
KS
Thanks for following up on the solution > I think there is a way of tagging the thread
as solved/fixed/etc
16yukon
