Warning: K&N PF-1000 Fuel Filter Does NOT Fit GMT-800 Tahoe Despite Listed Fitment
IHChris
Washington State
Just wanted to give other GMT-800 owners a heads-up before they order the K&N PF-1000 fuel filter.
K&N’s website lists the PF-1000 as compatible with a 2001 Chevrolet Tahoe, but the filter I received does not fit the factory application at all.
It’s almost 1/2 inch longer than the OEM filter and is also wider. Because of the additional width, it won’t slide into the factory plastic filter bracket.
I contacted K&N customer service about the issue, but unfortunately, they were useless. They didn't seem to care, or want to address the problem at all.
I ended up purchasing a WIX 33481, and it was an exact match for the OEM filter I removed from the Tahoe. The WIX fits the factory bracket correctly.
So if you have a GMT-800, I would double-check the filter dimensions before ordering the K&N PF-1000. Their fitment guide may say it fits, but based on my experience, this filter does not fit my 2001 Tahoe.
I’m posting this mainly so someone else doesn’t waste their time ordering a filter that won’t fit.
-Chris
alexblagoev
