Just installed a new Walbro 525 in the stock bucket and am seriosly disappointed in the result. Details:
2018 Tahoe PPV
Gen V L83 with BTR Turbo Stage 1 cam (w/38% fuel lobe)
New OEM L83/L86 HPFP
Single Turbo limited to ~15psi
Newly installed Walbro 525, directly replacing original fuel pump in the OEM bucket
Original pump would not raise pressure when called to (High Flow setpoint) and the HP fuel rail pressure would drop causing long injection durations. I thought this was a flow issue but new pump is worse. At least the original pump would hold 40 psi. This "upgraded" pump dropped to 16 psi today!!!!
I ran the output of the pump to the stock location to keep the stock pressure relieve and up the max pressure settings in the "Fuel Systems" to 560 to match the lower flow rate section since this pump should double the flow at the same pressure. I know the pump draws more amperage, but according to the curve provided with the pump, the amperage should be fine for the OEM FPCM as long as I keep the pressure limited.
Could the bucket inlets be choking the flow and and I'm starving the pump? This is the only thing I have come up with so far. Anyone else using the 525 in the stock bucket?
Seriously frustrating that it appears that I'm spending money and time to go backwards.
Any suggestions would be appreciated.
2018 Tahoe PPV
