Violent Downshift
itsbo1313
Louisiana, MO
So last night as I'm leaving Walmart making a left, as I straighten out to accelerate my 2012 Yukon XL Denali downshifted hard enough to scare everyone onboard. I was probably doing 10-15mph and eased on to the gas. It drove fine the rest of the way home. Should I be concerned?
no codes? might want to get a scan or use a scanner that will read transmission codes and/or abs
if you go by a dealership and explain what happened they might be nice enough to give it a scan (for free) and see if anything got stored, this doesn't obligate you to have them work on it but at least you will know how to proceed. just depends on the dealership some will no problem and some might say no $85 please.
Can anyone recommend an affordable scanner that can read trans codes?
I got this as a gift. It's pretty decent, but it's in the $300 range. For that price you could get a Tech2. 20180712_190652.jpg Btw--that's the code I'm getting in my Express van that has similar symptoms as what you're getting. It has the 4L80 trans tho.
DP2024
