odie301
ok i have an 04 tahoe with a 5.3. runs pretty darn good w/ my cai, corvette servo, and bb tune. But as always i want a bit more. SOOOO i am thinking cam swap.
What cams are good for a daily driver ( i have 130k on it already). I don't need the power to be top end by any means. Something with some good low end torque and a stiff mid range would be awesome.
So, what do the stock corvette cams do in these trucks? Are they more hp than torque or does it change a bit w/ our set up? How about cams made for these trucks, what is good?
With a cam install what stuff is an absolute must to replace? and what can slide? I assume you need some new springs (stock corvette or aftermarket?), and push rods?? Do i need new lifters? Do you have to remove the heads in order to get the new springs on, or can that be done w/ the heads installed?
Thanks for the help. in case it matters this is my daily driver..and i do some towing.. not a whole lot but i don't want to lose my ability to tow with a cam change.
