Abdullah576
- Joined
- Oct 11, 2022
- Posts
- 19
- Reaction score
- 3
Hey everyone,
Recently got a Check Engine Light on my 2022 Suburban and pulled these codes on my scanner:
U152D: LIN Bus 2 Lost Communication With Device 13
P00FF: Body Control Module Requested MIL Illumination
P0420: Catalyst System Low Efficiency (Bank 1)
When inspecting under the hood, I found heavy corrosion around the negative battery terminal, and the 2-pin connector plug going to the Battery Current Sensor was unplugged. When I looked closer, the plastic socket on the sensor had completely snapped off due to corrosion expansion, leaving the metal pins exposed/sticking out.
It seems pretty clear that the broken sensor connection directly triggered the U152D (LIN bus communication loss) and P00FF (BCM asking the engine computer to pop the MIL). I'm planning to splice in a replacement 2-pin pigtail (Standard Motor S2860) and install a new OEM battery current sensor (GM 13545953).
Has anyone else ran into this same issue with the battery current sensor rotting out and throwing these specific codes? Did fixing the battery sensor / pigtail solve all your electrical codes, or did the P0420 end up being a separate issue (like an O2 sensor or exhaust leak)?
