Turn Signal sounds weird - works fine?
Odii
Maryland
I don't know if this is PPV related or what
my turn signal works just fine - perfectly as expected, just passed MD state inspection too
but it *sounds* weird
bink bink, bink bink
it sounds comedic - like it would be impossible to be in a bad mood and turn on that turn signal, it makes me laugh every time.
i would like for it to not sound like that, but i'm not sure if this is a result of some of the PPV upfitter stuff and is expected to sound different or if there is something wrong
Sparksalot
Bastrop County, Texas
You've mentioned possible a head unit swap in other threads. Does the current head unit work? Are the speakers good? I ask, because when my front door speakers in thecopcar croked, I only had sound from the A pillar tweeters, and the signals did sound odd. All was good when I replaced the speakers.
Odii
Odii
Maryland
interesting.
I did replace the head unit with something i got on crutchfield --- nothing super fancy, but works pretty great and i'm real happy with it.
I guess it did occur to me that i never drove it and used the turn signal before swapping the head unit - so i don't know if related.
AND i was actually meaning to check if, in fact, i was getting sound from the front speakers - it *feels* like they're only coming from the pillar tweeters. so i will check that in the morning.
I'm very grateful for this site and for folks like you spark - it has made this journey a lot less scary than it could have otherwise been
Odii
Odii
Maryland
update: front speakers are working fine, wonder if i should replace to match the back ones anyhow
maybe i'll just have to learn to enjoy the weird **** ****
As @Sparksalot mentioned, interfaces for aftermarket HUs create turn signal and warning chime sounds since the factory ones are lost with the factory HU. Like factory, the sounds are played through the driver's door speaker. I've actually changed interface modules because of the turn signal sounds. I think my first one was a PAC GMLAN and I didn't like the sounds it made. I think what I now have is an Axxess GMOS. It sounds more like factory, but the signal sound is really low. I have a PAC RP5 on deck to swap in that should be satisfactory all around.
Odii
Odii
Maryland
This is the head unit and setup I went with. Looks like I got the pac rp5 you mentioned
I wonder if something isn't connected correctly in this case, because the sound is peculiar
Well, damn. I guess all of PAC's stuff just has a particular sound, and it's lame.
I doubt it. If everything else is working as it should, then it's probably just "that unique PAC sound". :disgust:
I'd say that you probably saved me the hassle of swapping the interface again. But, I'll probably do it anyway since the RP5 has the steering wheel controls built-in and I need the universal Axxess SW-1 for another project. I might look into the Crux. My Tahoe Twin buddy has this and I think his turn signals are factory-like in sound and volume.
SteveandKish
