Cutting bump stops does not sound like the most intelligent plan
If your vehicle is dropped, the suspension travel is decreased. Depending on the amount of drop, the axle or control arms may be bottoming on the bumpstops, causing a bouncy or harsh ride. You can remedy this by replacing the stock stops with shorter ones or just trimming off the needed amount from the original pieces. Suspenion companies make shorter replacement bumpstops for this purpose.
If you go about 5" or lower on the rear of our trucks, you can gain more rear travel by removing the welded on bumpstop bracket from the frame then remounting the bumpstop to the frame itself, gaining at least another couple extra inches of travel.
No, I typed cut the bumpstops some.
But, hindsight, I coulda been clearer
Ok. Mines 4wd and i want to go 3/5 drop. How hard is this going to be? Nobody pays attention at gmfs so I thought I would try here. djm has a kit, but on the website it says that it may cause it to bottom out. Can this be avoided and still use the 5" coil? Will cutting bumpstops down help this?
I cut the bumpstop brackets out of my truck about 7months after the drop. What a difference that makes. The driver side is a little harder to cut, the gas tank is in the way so a extra set of eyes makes it easier.
not trying to sound like a complete **** but you have no bumpstops in the rear whatsoever? This does not affect/hurt anything?
you'd have to drive more carefully. you wouldn't need them unless you wanna save your axle.
Captain, I went smooth and simple for the drop. I got 2" drop keys for the front and went with 3"coils for the rear.
IIRC it sits at 31" all around. I can double check if you really want me to..
Yea, I have to agree that the truck had the right amount of drop and sits level. Actually those are the stock 16" rims with P265-70r16 BFG Long Trails.
