Transmission Service? keep old fluid or put new..
BG1988
What do you guys think about doing a transmission service
it's 11qt that need to be replaced after swapping out the transmission pump (it has to be drained before service according to the dealer)
should i reuse the old fluid or put new fluid I got 12qt at $5.27/qt from oreallys auto parts
valvoline dexron 6 Full Synthetic (officially licensed )(NOT muti car formula ) (priced match walmart)
also a new drain plug on the transmission pan and aux pump it's 10$ but i don't want a leak
the SUV has 106k on it the fluid is clean no glitter
cfbf4524-a8fc-4d21-9a3c-351ad042a63f.a0c5a4b266d1af0f157a48ffb76d9f0f.pnggfhsrwtyw45yw45trt.JPG
B
BG1988
they're going to change the drain plug too so it does not risk leaking
