Trans free spinning on 1600 mile trip.
02Lightning
So, I did a 1600 mile trip in my 2008 Yukon Denali, and with the hammer down when passing at 70 to 80mph it will rev like it missed a gear or something up to 6000 rpm. Doesn't do it every time and no codes. It has 120k on it, and I've owned it from new. I've changed the fluid about three times from new and the fluid is full and doesn't smell burnt, no leaks. Any ideas?
petethepug
Michael
SoCal
My wife’s 07 convertible beetle is doing that. Time for a trans service. 120k seems about right
02Lightning
02Lightning
Trans. service? As in drain the oil and replace filter? I'm not sure there is anything else to do on these is there? 6L80E is the trans in these right?
petethepug
Michael
SoCal
Ha ha, the symptom not the vehicle. Those of us who dare to own non GM products tend know how they stack up against other brands, both the highs and lows.
gpracer1
Phoenix
If it happened once or twice in the past and is ok now it’s probably not a clutch pack as it would be toast and not intermittent. Probably a soloenoid in the trans, or wiring issue.
thompsoj22
california native "REPUBLICAN" high desert
yea that, solenoid or converter most likely since the transmission does not use pressure to determine shift points, the tehcm basically shifts the trans via solenoids when told to, no bands to slip, and no servos to leak/hang up. Your problem is it isnt a failure yet, I question not throwing a code, it just isnt a dtc, free spinning to 6k is ******* clutches. there are some really good youtube vid,s that show complete teardown and issues related to slippage. either way you should find someone proficient with a TECH2 that can run diagnostics and shifts to possibly pinpoint it. I have the same trans with 137,000 and i know my time is coming too.
02Lightning
02Lightning
It's pretty tough to describe, it's like the gear is holding, and then when it's gets to a point where it should shift, it's just like it's in neutral. I back off the throttle, and it works as normal again. I also would have thought the rev limiter would have caught it?
JohanZ
