Towing with 2011 Yukon Denali
RDEVans
Hey guys,
New to the forum and have a new to me 2011 GMC Yukon Denali. I plan to tow an '05 Jayco Jayflight 27bh (4950lbs empty). Any suggestions/advice on towing with the Denali? I'm sure the 6.2 should easily pull it. Have a weight distributing hitch, and have a trailer brake controller installed. Plan on going about 60-63 mph. Should I go in manual mode and have 5th as the top gear? I'm guess at 63 I wouldn't get into 6th anyways, but curious about best RPMs to be running. Going to be flat or gently rolling hills (KS up to WI through MO and Iowa).
Any advice or suggestions would be greatly appreciated, thanks!
Geotrash
Dave
Richmond, VA
Hey guys,
I tow a similar sized camper with a 2012 XL Denali. I run in M5 with tow/haul mode on to lock it out of 6th or it hunts in/out of 6th too much at 65.
Hey guys,
If you want to have hotel power back to the trailer, there is wire taped up under the brake booster that once unfurled can be attached to the other post on the front of your underhood fuse block to send power back there when the trailer is connected. Remember though, that if the truck is off and trailer connected, it is still sending power back there, so don't let it discharge your battery.
Dave, would it be worth a BlackBear tune of the transmission for such work? I would think so but don't tow as much as you guys.
Welcome to the Forum from NH.
Pics of the truck, please.
donjetman
I can't remember what the 2nd wire if for, but I hooked up both for towing. My trailers always have their own battery and the brake controller mounted in/on the trailer. DSCN9998.JPG
R
RDEVans
Thanks for the advice. What do your RPMs run at when you are in M5 at speed?
R
RDEVans
Sorry, one more question. Trans temp should be running at about +100 over ambient air temp? I've heard that, just want to make sure the same with these rigs. Do the Denali's come with a trans cooler as well? Ok, thanks again!
R
RDEVans
Thanks! Good heads up on not letting the battery become discharged.
R
RDEVans
Yes indeed, great advice already! I'll throw some pics up once the rain stops and the mud dries up. The ol' girl little dirty right now!
btheboyscout
