I know for sure a 2008 Suburban 6.0 can have a 14 bolt with 4.10s. That's what the donor was for mine.
Don't have enough HEAVY towing experience. My GUESS is,BREAK BREAK
Is it worth getting an OEM brake controller and knee panel, or should I go with an aftermarket controller?
I personally think trailer brakes are a must anytime you are getting close to the tow vehicle weight on the trailer. 7k behind you with and without trailer brakes are two totally different things. Most aftermarket brake controllers are pretty easy to wire up.
Also able to place them out of the way most times and can unplug them and store them while not in use.
I know on the gmt800 there was an adapter pigtail tha was available for the aftermarket brake controllers that pugged in under the dash if the vehicle had the correct tow package equipped. I forget the rpo code for that. Idk if the 900 has the same thing.
I guess it would depend.BREAK BREAK
Is it worth getting an OEM brake controller and knee panel or should I go with an aftermarket controller?
If you wouldn't get the benefits of an integrated controller, a Tekonsha P3 is best.
Oh Wow !! Only 1 mpg.. That really sways me toward the 4.10's for sureI lost about 1 mpg on the highway, driving a constant 75 mph.
When I do the gear change in the 9.5 14 bolt, then I'll def upgrade the differentialThe half-ton/9.5s never got better than 3.42. Thanks to CAFE mileage regs. The 3.08 is an abomination and an affront to man and nature that should not even exist. I call it the soccer mom ratio.
The 2500 Yukon XLs/Suburbans (no 2500 Tahoe) all got 3.73, and the 2500HD pickups got 3.73 or 4.10, but again that was the 10.5" freefloater, not the 9.5" semifloater.
The 9.5" is only rated to ~4300 lbs. The 10.5" is rated at 5500 lbs in my application, 6000 lbs in the pickups, and the axle itself is rated to 8600 lbs by the manufacturer, American Axle. E load range tires limit the rating to about 6000 lbs.
Turned off in the tune or did you replace the camshaft? If so, which one?Since doing the 5.3L DoD soft delete...
Only turned it off in the tune, no hardware changes. Instead of pulling the heads, I'm doing an L96 swap at some point.Turned off in the tune or did you replace the camshaft? If so, which one?
Well as the old saying goes there is no replacement for displacement.Only turned it off in the tune, no hardware changes. Instead of pulling the heads, I'm doing an L96 swap at some point.
Speaking of cramming ...... no replacement for displacement.
Unless you cram more air into it ...
Too bad diesel costs so much lately, we all need to get better at figuring out how to reuse cooking oils or something ......
a TURBOdiesel will win in towing 9.9 out of 10. You probably don’t need / want it, but it sure is nice to get 25MpG empty on the highway, and still tow 15k when needed.
