Throttle Body Vacuum Leak?
IQIHUI_Auto
Ningbo, China
A slight wisp of smoke around the throttle blade shaft return spring during a pressurized smoke test is actually quite common on older GM throttle bodies. The shaft rides on bushings rather than a 100% hermetic high-pressure seal, so pushing 1–2 psi of smoke into the intake will often force a tiny bit out past the spring side.
In most cases, that minor shaft seepage alone won't cause a major rough-running condition unless you can feel physical radial play (wobble) in the shaft that lets unmetered air rush in under high vacuum, or causes the blade to bind near closed throttle.
Before condemning the throttle body assembly, I'd double-check:
  • The throttle body mounting gasket and plenum sealing surface
  • IAC / TPS O-rings (if applicable to your year)
  • PCV hose and intake manifold lower/upper gaskets
If you wiggle the throttle linkage by hand with the engine idling and spray a tiny mist of carb cleaner right at the shaft spring—if the RPM doesn't jump or stumble, that shaft seepage isn't your primary culprit.
Marky Dissod
... pushing 1–2 psi of smoke into the intake will often force a tiny bit out past the spring side.
Even if the smoke test is under very light pressure like 1-2 psi, any leaks that show up are still relevant,
because atmospherically aspirated engines SUCK harder than 2psi, especially under load.
Yea, I said SUCK.
OMG, I found the issue. All these vacuum leaks of course are good to fix however, I was like why on earth would a tiny vacuum leak that was likely already there cause the engine to stumble.
Originally I thought it was a bad coil and IT WAS. I took all the coils off and did an impedance check. I'd gotten one misfire code on a cylinder and that coil was at 6.4k versus 5.2k for the others. I swapped it to another cylinder and problem seemed to go away. Also I never got codes again.
I did have a burnt up catalytic converter on the side that registered the code though which corresponds with the rich mixture. On that bank. I opened PIDs in my scan tool to check misfire history and counters, they were all zeroed out which really threw me for a loop. I turns out the tuner disabled all those counters in my tune. I had no idea.
The PCM steered me in another direction entirely looking for vacuum leaks! Not in vain as I had a bunch which have been resolved (note the starter fluid, brake fluid, propane, method SUCKS, it never revealed any of these leaks).
I bought spark plug test light last night. Plugged it in to the originally suspect coil and whola, it didn't illuminate. I swapped coils cylinders, plug wires, etc. Where ever that coil went the light didn't light up.
This was an intermittent failure of one of the ignition coils. I have learned a TON though...
It would be prudent to make a make a connector to plug into a coil with open leads (get a pigtail)... Then cut an old spark plug wire to give you another lead... Connect these to your coils and check impedance periodically (say every 25k miles after 200k miles). If you have a coil that is registering higher than the others, then it's going bad. Replace ALL your coils due to age. I lost a catalytic converter due to not catching this which is a bit $$$$
Additionally, this vacuum leak / smoke tester is vital kit IMO. You want to periodically say again every 25k miles check for vacuum leaks in your exhaust, motor / intake, and fuel system. My trims were likely drifting for a while and I never noticed. This affects your motor in subtle ways as well as gas mileage as vacuum leaks cause the PCM to constantly hunt in search of correct mixture.
Dang thanks guys for helping me with my sanity. I'm going to install the new throttle body and see if it helps with that leak... I also want to take the old one and continue searching for seals to rebuild it.
a quicker method in the future is to just unplug the coils one at a time. The one that makes no change is the bad one. Been there done that.....
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Great tip. I actually tried that, but seems the coil was intermittent so made it hard to tell for sure. I also tried unplugging and plugging in injectors. As of yesterday though, cylinder #5 was flat dead. No spark at all so that would have worked quite well. This was a BEAR to get sorted out.
I also contacted the tuner that helped me. He didn't delete but rather desensitized the misfire detection. I think to the point it does not do anything as there was a dead hole there for sure and it didn't even notice lol
Thanks, I determined the underlying issue is actually bad ignition coils. Although, discovered several vacuum leaks in process the throttle body shaft seal being the last one.
I tested the TPS, IAC, and vacuum line for leaks. They are fine. It's the shaft. My seal is completely crusted up. When I tried to pop it out, it started to crumble. Likely as you mentioned they all leak, I'll know how much better if any a new throttle body is as I have one on order. $135 Bosch one from eBay. Either way, I'd like to further research sealing that shaft better. The factory has a seal there. It's dimensions are:
0.84 x 0.38 (to 0.37) x 0.12 inch
I saw some people use an oil seal for a snowmobile on aftermarket throttle bodies. Specifically a 0930-060 for a artic cat snowmobile. It's 0.39 x 0.89 x 0.19 though. Not sure it would work being 20 thou larger than the shaft itself.
Last note, it wouldn't hurt to periodically soak that seal in ATF or some other fluid to condition the rubber. They are all crusting up and dying after 20+ years of drying out.
IQIHUI_Auto
Ningbo, China
@Matthew Jeschke Glad you tracked down that dying #5 ignition coil—and what a curveball having the misfire counters desensitized in the tune! From a manufacturing standpoint, seeing 6.4k ohms vs. 5.2k ohms cold is textbook thermal fatigue inside an older GM coil pack: after 200k+ miles of heat cycles, hairline micro-cracks form in the epoxy potting and secondary winding. Cold on the bench it still bridges with slightly elevated resistance, then opens up completely once heat-soaked under load. (Also worth keeping an eye on that bank's upstream O2 sensor since raw fuel took out the cat—unburned fuel and overheating often make the upstream sensor lazy too.)
On the throttle shaft seal dimensions you measured (0.84" OD x 0.37–0.38" shaft x 0.12" width):
- Skip that 10x22x6mm (0.394" ID) snowmobile seal—being ~0.019" oversized on the ID means zero radial lip interference on a 3/8" (0.375") shaft, so engine vacuum will pull air right past it.
- What GM used there corresponds to a standard inch-size thin cross-section lip seal: 3/8" shaft (0.375") x 27/32" bore (0.844") x 1/8" width (0.125")—look up an industrial cross-reference like SKF/CR 3712 (nitrile) or a Viton/FKM equivalent in that exact 0.375" x 0.844" x 0.125" envelope.
One quick caution on conditioning rubber: avoid soaking a throttle shaft seal in ATF. Stop-leak/seal-swelling additives in ATF will soften and swell NBR rubber, which can make the lip drag on the shaft and cause a sticky return-to-idle. A tiny smear of pure dielectric silicone grease on the lip during assembly will keep it pliable for years without swelling.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
That's good info to know!
For sure, somebody on LS1 tech told me they source the seals in MM. When I'm able to fully tear it down I'm going to see if I cannot find a seal in the McMaster Carr catalog.
Excellent, thanks!
Good to know! The ATF additives maybe a bit too strong.
Is it time to add SOLVED to your thread title?
The root of my symptom was coils but the throttle body still leaks, needs rebuilt for which I'd like to continue this conversation.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
The new throttle body arrived. It seals perfectly, no smoke comes out anywhere on it, including around the shaft.
However, it didn't have the crankcase vent fitting. I discovered there's two versions of the cable throttle body where one has it and the other doesn't. Did GM do away with venting the passenger side valve cover on later models? I'm wondering if I return this thing or cap off that vent on the valve cover.
IQIHUI_Auto
Ningbo, China
@Matthew Jeschke Definitely don't cap off that passenger-side valve cover port! On the Gen III Vortec PCV circuit, the driver-side rear port pulls vacuum into the intake manifold, while that passenger-side valve cover hose is the metered fresh-air makeup inlet.
GM didn't delete passenger-side venting on the versions without the throttle body brass nipple—on those setups (non-EGR / transitional years), that fresh-air hose simply moved over to a quick-connect port on the plastic intake air bridge/resonator tube between the MAF sensor and the throttle blade. If you cap the valve cover off completely, crankcase vacuum has nowhere to draw clean sweep air from, which traps moisture/blow-by and can start pulling past rear main or pan seals. And if you put an open mini breather filter on the valve cover, it lets unmetered air into the PCV loop downstream of the MAF and throws your fuel trims lean all over again.
Easiest move: either swap for the early cable TB with the press-in nipple, or keep this tight-sealing TB and add a clean 3/8" barbed grommet/bulkhead fitting into the plastic intake tube *between* the MAF and the throttle body so the makeup air stays 100% MAF-metered.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Thanks, I returned that throttle body and plan to buy one with the provision for the crankcase vent.
I noticed studying further as you mentioned GM located the vacuum port elsewhere from the throttle body. I was nervous to even try running it with out for reasons you'd mentioned.
Thanks!
Charli1964
Member Recommended
