Elon Powell
on my 1999 escalade (5.7) i drove it hard for 10 minutes and the gauge will only get up to about 160 maybe it is overcooling or a bad gauge please help
ok thanksMy 96, with a newish coolant temp sensor shows 160 on the gauge, but the engine coolant temp is 195. You need an OBDII tool to check ECT. The bluetooth gizmos that cost around $20 will give you this and more.
Is this a new thing? Have you done anything work on our Escalade lately?on my 1999 escalade (5.7) i drove it hard for 10 minutes and the gauge will only get up to about 160 maybe it is overcooling or a bad gauge please help
it is a new thing it used to run at about 190 i will probably scan it and see if that will tell me somthing thanks for the helpIs this a new thing? Have you done anything work on our Escalade lately?
As @96-2D-Hoe said, getting a scan tool will give you a better idea of what’s going on.
Maybe your thermostat has stuck open. For the couple $'s it costs I would just change it, and the rad cap too.it is a new thing it used to run at about 190 i will probably scan it and see if that will tell me somthing thanks for the help
ok the thermostat is fairly new will probably scan it and then go from thereMaybe your thermostat has stuck open. For the couple $'s it costs I would just change it, and the rad cap too.
Any OBDII capable scan tool will give you the engine coolant temperature
Sh*t happens. Don't rule that out.the thermostat is fairly new
