camperhead
Got my new Tech 2 clone tool today. It will not connect to any vehicle that has to use the CANdi module. I have tried to run the two CANdi test and it fails both of them. Any insights or do I have a bad tool?
Ive tried it on three vehicles. First two with the CANdi module 2011 suburban and 07 Duramax, both said" Candi module was not detected for Tech2" then I tried it with no module in a 1998 S10. It connected to it no problemtake it all apart, make sure everything is clean and looks good, put it back together (tight), it has a self test function in the menu.
also there are a few unsupported vehicles, what are you trying to use it on?
Best I can tell it depends on the specific vehicle. GM starting add CAN Bus as they went along. My verison 33.004I just got my Tech 2 but have not used yet. Same software upgrade number. Maybe you have a bad CANdi module? I am really curious now. I have an 02. What years did it start to be a must for the CANdi module?
I'm not sure what you mean by take it apart? Take the ends a part or what? They are clean and very tight to push togetherdid you do what I said to do? and then run the self diagnostic? the cables & connectors on these need to be tight, I always check mine before I use it each time.
My version is the 33.004 as well. I just assumed that maybe the CANdi module is not needed till NNBS 2007 and higher/newer.
