swapping wheels - question on tpms sensors.
aztec
Good morning /afternoon everyone I have a question on swapping wheels on my 2016 Yukon Denali.
I putting the same exact wheel just a different color ( they both genuine gmc wheels)
I would like to know if I can use the same tpms sensors I have on right now ?
Do I need to do any sort of programming ?
thanks in advance.
You can swap out the TPMS sensors off your old wheels and install them on your new wheels. If you swap out and install at the exact same wheel position, you won't need to do anything, and the truck's current setting on which wheel is on which axle will be the same.
If you don't know which was which after mounting the tires and mounting the wheel/tires to the truck, then you will have to do the TPMS reset/relearn procedure.
thanks in advance.
You can use your existing sensors on the new wheels and unless you put them on the same position they came off, you will not have to do a relearn.
A
aztec
thank you very much guys I greatly appreciate all your help..ill post before and after pics
Harry26
