Looking at the factory external trans cooler on a 2500hd with 8.1/Allison drivetrain and I noticed how much larger of a stacked plate cooler it is. Early 2000 trucks are showing up at the local pick your parts and I've seen this cooler repeatedly. Thinking about retrofitting it onto an 04 Tahoe. The only adaptation that will be contended with is the line size difference. The hd truck has 1/2" lines, whereas the light duty and 1/2t vehicles have what I think is 5/16" line. It should be easy enough to couple the lines together with fittings. Anyone else tried this previously? Good results, bad results?
