Suspensión question
Amp653
I’m sure this has been spoken about but had a question. What will bring back me to civilian ride suspension? I know what I bought but eventually the wife will be driving it and want to make it comfortable for her. Thanks in advance.
Tires will make the biggest difference. If running a 17 inch wheel, you want a 70 series tire instead of a 60 series. Then you'll want to replace the cop shocks and cop springs.
A
Amp653
I would agree about tires. Struts we’re just done prior to me buying it. A set of billsteins shocks and springs would make that much of a difference?
A
Amp653
That's subjective, start with the tires and take it from there. Basically, you'll want to convert it to a ZW7 Premium Smooth Ride suspension to change it from one to the other if the tires don't do enough.
But did they install the replacement specifically for the PPV suspension? The PPVs are spec'ed to have firmer shock and strut valving. As @swathdiver said, change the tires if it still has the ones spec'ed for the PPV, even if it's just the size (not necessarily the speed rating). If this doesn't suffice, get "civillian" springs and shocks/struts. The springs can be found everywhere new or from people that lowered or lifted their rigs. The tires and swapping out the springs will raise it to standard Tahoe height. The taller tires will make your speedometer read slow, too.
Bilsteins are often hailed as the best-riding shock on these, but there are others that are a little more budget-friendly. I think the Monroe Sensa-Trac line is one example of these. No personal experience, though.
Fless
Super Moderator
Elev 5,280
Perhaps the new struts have a label on them so you could get the mfr and model, and look them up to see if they're civilian or PPV type.
A
Amp653
I was under there today but could only see part of the sticker at bottom shock. The tires are still the factory RS-A with 17” rims.
hdheffel01
