Supercharged 350 vortec
uli93
I recently bought a used engine for my 99 HOE it's a same year motor out of a suburban it comes with a Carroll supercharging supercharger . I find it weird it's a huge charger says "Mach 2" I really don't know much about them. It's not intercooled . Pipes only connect to throttle body an air filter box . Not muh wiring to it . Looks like a plug and play or should I say bolt on and go kit . Anybody have any thoughts To it ?
cowboyzr2
Magnolia, TX
Used to be carrollsuperchargers.com but now you can find them at http://www.blowerworks.net/
He originally started out playing with 3rd gen Firebirds/Camaros IIRC, but now is pretty big in the Vette community. I know Carroll is popular among Dodge V10 guys, too.
I've never heard of one on a Vortec 350 though... I'm sure if you call or email they'd give you more info.
U
uli93
here's the engine . Yes does look like a pro charger . Has a oil filter connected to to the charger and came with a superfueler meter box throttle body has a spacer with an extra fuel delivery injector running in the spacer . I'll post more pics later since I'm at work
jdpber
GOLD MEMBER
The America
pM Jenna Bear she can either answer any Q or hand you to Justin for a more in-depth technical discussion.
xanatost
Lafayette, La.
Lucky sob!! I been looking for a S/C for my hoe but only can find bits and pieces here and there. You have a whole dam thing!!! What kind of condition is it in??
U
uli93
Don't know yet lol we're installing the motor just now lol ill keep you posted
TahoeLimited
Fountain, CO
Pic not showing. Would love to see 'er...
lucky013
I just noticed this an older post but I just recently came across the same procharger...says "mach II" on the procharger itself and carrol supercharging on aluminum plate?
drakon543
They generally are around 6-8 psi with a procharger. They are also typically not plug and play. Sometimes requiring different injectors brackets fuel pressure regulators and a tune to run correctly. If you only have the procharger itself it would be much simpler to find a full kit and do it yourself rather than having a shop figure out what else it needs to run it and doing the tune.
lucky013
I know this is an old thread but I have the same procharger and was wondering if anyone knew more info by now?
lucky013
Oh ok thank you ...I actually have everything needed for the kit including superfueler
lucky013
I was curious on trying to find how the tube system ran to procharger like meaning which outlet do you run to the throttle body because it seems set up almost backwards with the center outlet running to the throttle body and the outer outlet to the airfilter
drakon543
It's not really a supercharger but it's also not really a turbo. Kind of a wierd setup to begin with but for those only ever looking for that 6-8 psi of boost. It also doesn't require the amount of work as a supercharger or turbo setup and doesn't generate the intake heat as a turbo. Hence why most procharger kits have the option of with or without an intercooler.
lucky013
You're right it is some sort of mix between the 2. It has straight splines and the pulley directly spins the splines no other gears involved. Seems more closer to a turbo that's belt driven
lucky013
Procharger made successful transplant into 92 mustang 5.0 bored .30 over, new piston + rings, pro comp cam with rollers, gt40 intake, 24lb injectors. Starts and runs fine but think it might new slightly bigger injectors or a BAP. Waiting on new tube system with a blow off vavle
smiley750
