This graph below should give you an idea of Oil Temps vs Coolant Temp for a 15 minute drive that has few traffic lights and minimal traffic. Pretty ideal conditions overall.
Based on this behavior, you should be able to expect that at 80F ambient this 15 minute drive might only get the oil temp up to 160F!
If I get a chance now that the weather has warmed up, I may try to get another data set for a warmer cold start to see the data tracks.
So this all being said the OLM may actually be pretty good at predicting oil life. Personally I will typically not run the OLM below 50% or maybe around 150 hours. Still trying to figure out the best OCI for my requirements.
At 8274 miles, my engine has 191.45 total run hours. 27.86 "Idle" hours and 48.9 "City" hours per the ECU stored data hours. So this means my engine has 142,55 non "idle" or "City" hours at this point. I have not tried to calculate what percentage "Highway" miles I have on my truck, but I would say around 75%.
As for oil analysis info, I would pay close attention to Aluminum due to the current bearings being bi-metal steel/aluminum. Seems for some reason up to the L84/L87 GM was using coated rod and main bearings, at it appears that GM stopped using the coating on the rod bearings once the L84/L87 were released. Not sure this is 100% the case, but many of the L84/L87 teardowns have coated main bearings still, but uncoated rod bearings.
