Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Hey guys, any good resources for replacing the input shaft seal on the steering gear (04 Burb w/ 7,200lb hydroboost brakes)? I have a slow leak that I would like to fix and have no need to replace the entire box.
Seal kit $22 bucks google it . I did mine it's still leaking . I need replace the steering gear and now trying to figure out if last owner replaced pump with wrong one.
I ordered a seal kit today as well as a new pump which I believe is the correct one (I have the hydroboost brakes like you do). My pump is beginning to whine partly because I blew out the cooler last fall, I only noticed how noisy it was now that it is warm enough to drive with the windows down. I have avoided the Lucas oil and any other treatments as they only soften seals. It's only a matter of time until they blow out completely.
Google this one 503-0159 [emoji106] or 503-159 . 4 hole shaft going to steering wheel first plate there either 3 hole or 4 hole. 3 is 670 4 is 680. If I'm wrong let me know.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
