H8 PVMT
- Joined
- Nov 30, 2009
- Posts
- 58
- Reaction score
- 7
I have a 2000 Yukon, 295,000 miles on it. Lately I've had a problem and I'm not sure what it is.
I'll turn the key to start it and I get nothing, not a click not anything. I can wait about 5 min or so try again and it starts right up. I've also had a couple times when it will not do anything, start very rough and then die. Try again a little while later and it starts right up and runs great.
What I've done recently, new starter. New mass air flow sensor. Changed all the plugs and wires.
I did notice that the negative connection on the battery has a fine line between a solid connection and falling apart, that might be the cause of the truck not doing anything but it's not part of the truck running rough and dying.
Any thoughts or suggestions? Can the ignition cylinder go bad and cause this type of sporadic problems?
