Hey, I’m new here and looking for some ideas. I have a 2008 Tahoe 5.3 with 96k miles and I’m having some starting issues. It seems like it starts acting up when it is heat soaked but even then it doesn’t do it all the time. When I go to start the vehicle it like misfires for a second or so then starts up, some times are worse than others. It also has a slight rough idle. I couldn’t figure it out so I took it to reputable shop and they said the only time they got it to act up was when they had it heat soaked and turned it off it said the fuel pressure was climbing of key off engine off. So, they seemed to think the regulator could be sticking open. So I replaced the whole fuel pump assembly with an acdelco. It seemed like that took care of the issue for a few days, no starting issues and smooth the idle out. Then it started acting up again with the same symptoms. They did a leak down test on the injectors and those tested good so I’m kind of stumped. I checked the fuel pressure and it is in spec even had my buddy who works their double check with his guage just to make sure. The check engine light has never came on and also has not had any codes stored. Is it possible that my fuel tank could be holding slightly more pressure than it should causing an issue? Also I went ahead and changed plugs and wires because it was due anyways but the plugs didn’t look very bad. Any help I would really appreciate, I’m just looking for any direction to go after.
