Stabilitrac, traction control, and abs lights only in the morning
phaley99
My 2008 Tahoe with 120k miles just started giving me the stabilitrac off, traction control off, abs disabled lights but only when I start it for the first time and drive to work. The truck doesn’t feel any different when driving with these lights on. Only thing that could be causing it is my CV boot is tearing and needs to be replaced.
wsteele
Are you getting any codes? Like wheel speed sensors, etc?
phaley99
phaley99
Don’t have anything to pull the codes with. Just started yesterday so I haven’t gotten it to a shop or anything.
wsteele
Some auto parts stores have basic scanners and will pull codes for you. Something like a C0035, 40, 45, 50, C0131, etc. would tell you if it was an ABS sensor issue.
wsteele
No, there's a lot of things that could be causing those lights least of which is grease being flung out from a torn bellows boot. A basic code reader is not going to help you, you need a scan tool that can read chassis (ABS) codes. Who do you know with a Tech-2? Live in Florida? There are a number of us on here with them across the state.
Geotrash
Dave
Richmond, VA
I have this little guy that I take with me on trips. It's like a mini Tech2 in terms of being able to read both data and codes from all of the modules. Can't do any changes with it, but it's great for the money.
phaley99
phaley99
My buddy said he’s got something that should pull the code so I’m gonna see if his device will work. Will update
madmax442
