Spare tire hoist not raising or lowering beyond a small range
acrilyc
2004 Tahoe LS
So a few weeks back I had to use my spare. The hoist/winch worked just fine to get it off, and it went right back up.
I got the blown tire replaced and today I planned to get the spare back on.
However... After trying to lower it, it lowered a bit then started clicking, like a ratcheting noise. It'll raise back up a bit and the clicking will happen again, then lower back down until it stops and clicks more.
It's not the safety latch, which seems to be the issue in every thread I've looked at. The safety latch is down, hanging below the barrel. Pics included.
Any advice would help a ton. I just want to get my spare tire back on and I really don't want to replace the hoist. Luckily the tire isn't on right now in the case I need to. I'm not opposed to taking it off and inspecting it either, I just hope someone has some trick I'm not privy to.
It's been a Florida truck its whole life and as you can see it's all pretty rust free, so I don't think corrosion is an issue (plus I JUST got the spare off a few weeks ago with no issue!)
Thank you!
justirv
2004 Tahoe LS
Thank you!
I had a similar problem on my '02. If I recall, when winding it back up, the cable needs to have tension on it the whole way up. Else it free spools in the drum, gets tangled, and becomes useless. I think I ended up pulling it to see if I could disassemble, but it didn't look serviceable, requiring fasteners to be drilled out, etc. I went ahead and replaced at that point. Frustrating, yes.
A
acrilyc
This is my worry. I just sprayed the hell out of it with silicone grease but I doubt that'll do it since it lowered just fine before. I'll try a few things but I'm betting on having to replace it. Thanks for letting me know how it went for you!
EddieC
Surprising. Your's looks new compared to my '08.
homesick
The Best Me I Can Be
Navy Air Force
His post makes sense to me. It's consistent with winch lines and such.
Maybe, if you keep tension on it, you could work it back and forth, with the intention of pulling it all the way out. Then, try retracting it while still keeping tension on.
Don't forget to c*o*c*k [preschool censor alert] your hat and to hold your mouth just right.
joe
alexblagoev
