Spacers?
Alex33
Hi guys and gals, I did a little trail running today. Yay!! Here's the issue. I aired down a little to smooth out the ride and I noticed the front tires are rubbing on the uca. I'm thinking a .5" spacer should work but my tires are now toast :( Have any of you gone wheeling regularly with a spacer? How big did you need? Here's a tire pic for reference, this is after 4hrs on the trail and the drive home 20190629_164222.jpg
LTG515
Bump! Interested in wheel spacer details as well. I haven’t had this issue (yet) but at full flex in the rear, my tires hit/rub the inner fender liners of the wheel well.
LTG515
Still interested in this post.
Alex,
What are the specs of the tires you’re running? I’m going to be getting 285/70r17 General Grabber ATx’s and don’t want to run into the same issue as you when I air down.
Sent from my iPad using Tapatalk
A
Alex33
Alex,
Goodyear Duratracs 315/75r16 tires. I ended up doing a .25" spacer and it's good to go.
LTG515
Ok cool! And you’re all good with that small of a spacer? Still stays hub centric and stuff?
A
Alex33
It's good for now. I regularly remove the wheels/tires to inspect.
SnowDrifter
Washington. The desert side not the Starbucks side
Hi guys and gals, I did a little trail running today. Yay!! Here's the issue. I aired down a little to smooth out the ride and I noticed the front tires are rubbing on the uca. I'm thinking a .5" spacer should work but my tires are now toast :( Have any of you gone wheeling regularly with a spacer? How big did you need? Here's a tire pic for reference, this is after 4hrs on the trail and the drive home View attachment 225807
Not myself. But a group of friends I tag along with; They run spacers on their rigs without issue. Larger 1" ones. But they got the nice ones. Not the china garbo. I can find out what they run if you're interested
btheboyscout
