Skid Plate options - 2002 Yukon SLE?
321Gone
New here. I tried a search for my answer here but came up blank. As did my search online. Does anyone know if skid plate options for a 2002 Yukon SLE?
S33k3r
Dallas, Texas
Look at all the GMT800 as well: Avalanche, Escalade, Sierra, Silverado, Suburban, and Yukon. Also, some may have a plate to protect the rear differential as well.
Look on FB Marketplace, Craigslist, OfferUp, etc. You are looking for parts-outs. I suspect the the skid plate stuff is the same from 200-2010, but don't quote me on that.
All I found that’s stock for my 02 Denali is the 2-piece plastic set that are up front, engine and trans. There are aftermarket metal ones, kinda spendy. I don’t have links though.
There is one front metal (aluminum) factory skid plate for gmt800's they are rather hard to find but came with the z71 package.
it fits all 1500 gmt800's 00-06, note that it should come with some rather oversized rubber grommets, they are required for proper fitment, sometimes one or more are missing I think you really only need the front 2. the bolts used are the same bolts used for the plastic one, they are self taping and can be found on all gmt800, 900, t2. usually they are laying around in the rocks in the junkyard for the plucking.
there is also the standard transfer case skid plate that is often marketed for the colorado it fits all gmt800's, gmt900' and t2's.
Forgot about that Z71 one. I remember trying to find one and gave up. Got a part number on that tcase one?
ratty looking set
better but higher priced, in this listing there is a link to a couple more
I remember finding my 1st one at the junkyard scored it for like $10 or something, didn't know they even existed at the time I was stoked lol that plastic one is for the birds...
ratty looking set
Pretty proud of them huh. :D
The plastic front set on mine is good enough for me. I just mainly wanted to clean up the look under there, not even sure why since I’m lowered so I can’t see it and rarely go off road. Been in a couple rough areas and never had anything hit down there. I ended up replacing the front one with new because the old one got damaged being R&R’d so many times.
Woned2004
