Sisters mechanic 2002 Chevy Tahoe
halfpint2523
Hey y'all
I am a trained diesel mechanic .. ASE parts pro .. paint and body person ..
My sister has just bought a 2002 Chevy Tahoe Z71 5.3l ECT ECT .. Georgia truck ( zero rust) .. we live in Maine land of rust .. truck runs amazing .. has a couple small body holes I'll have to fix .. and someone decided to chip bondo out of the hood so I'll have to fix that now too .. but my biggest issue is I have a battery issue I have to fix .. I think I've traced it down to the aftermarket radio install .. but it's a rumble of single color wire ..
strutaeng
Dallas, Texas
Welcome! Sounds like a good truck to import into the Rustbelt, USA.
What is the issue? Parasitic drain?
I'm not sure if you know this, but the GMT800 trucks are broken into the 99-02 and 03+ years. There are very different on the interior wiring and engine/ECU wiring, although the engines themselves are the same.
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
H
halfpint2523
Yes I have a drain .. the interior lights stay on .. the clock stays on after the keys are out .. and sometimes the rear cargo warning light on , on the dash ..
I'm thinking it's the radio .. they installed an aftermarket ..
Thank you I did not know the break down of the years .. body wise they all interchange tho correct .. no body line changes ??
Missy
strutaeng
Dallas, Texas
Missy
Yeah, body wise yeah they're all the same.
PG01
Up here to the right
Missy
id check the door latches. Not sure about 02 but later years the switch for dome and rap is built into the latch, no little plunger switch anymore
Fless
Moderator
People's Republic of Colorado
^^ This. A good bidirectional scanner might show the status of the latch (latched or unlatched), but I'm not sure if the 2002 door latches have that reporting ability. I would think they do.
houstontaylor
Is the symptom that it does not crank or that you checked the battery and it is depleted? On a vehicle that old the starter motor can be bad if it is the original and give the appearance of a bad battery with slow cranking.
justirv
Missy
The interiors, dash, console, IPC, seat covers, etc., are separated as well, '99-'02, and '03+
Mariam26A
