Side marker light flicker
jnicks01
Chicago
Hi All. I've had LED side marker lights in by 07 for years without issue. I just noticed that the 2 fronts and passenger rear now have random flickering (on and off with no real pattern) when the truck is running. Before I do the tedious task of removing the headlights, can anyone chime in with a real solution? From what little info I can find, it may just be a bad bulb that is causing a "ground Hunting" in the system.
Thanks for any input.
replace bulb, I would recommend Genuine Auxito (there are fakes out there)
BlaineBug
Clown World
I'll agree, the LEDs are crap, I had the same problem with another car I used to have when I installed LED interior bulbs that were super cheap, once in awhile one of the would die and start flickering.
Woned2004
