Shifts hard into drive and reverse.
Chris Mckowen
2004 Yukon with 186K. When I put into drive and reverse, it goes in hard, makes a clunck sound, but not like a u joint, more like just too much pressure. Also sometimes does this when I get on and off the gas while driving. Any ideas?
SnowDrifter
Washington. The desert side not the Starbucks side
Hard shifting?
How's your fluid look?
How do the accumulators look?
What's your line pressure?
Clunk?
Check basically every mount and u joints. Dont assume they're good cause if they're not, you'll spend a lot of time repairing around the issue
CountryBoy19
Southern Indiana
Hard shifting?
Clunk?
And if your U-joints are good, pull the caps off the rear joint and rotate your differential yoke... Do it rotate more than 1/8"? If so, you have worn spider gears etc in your diff. I just replaced mine and my clunk is finally gone!!!!
DefiantOne
