Service airbag light came on?
JML07denali
My light came on out of nowhere and it's on a 2007 Yukon Denali. Where should I start to diagnose? Any help is appreciated.
denalianyone
NYBlackLade08
New York
Front sensors under the splash shield in the front. They are a bit pricey but it solved my air bag light problem.
BeenChevy
Minnesota
Re-seat the wiring harnesses under your seats first. If that doesn't resolve it, start your diagnostics with a Tech2 and narrow it down. You're dealing with yards of wire loom between the sensors.
denalianyone
NYBlackLade08
New York
But check the wiring harness under the driver seat first near the center console like mentioned above.
JML07denali
JML07denali
Is the airbag harness under the driver seat or the passenger seat?
BeenChevy
Minnesota
Under the passenger for sure. Someone on here should have the schematic. I can't remember if the side impact also routes under the driver. Any luck with a tech 2? The dealer can pull the specific location of failure... For $100 unless you're a schmoozer
JML07denali
JML07denali
I'm going to try reseating the harnesse first. I called the dealership they said there is a recall on this but GM hasn't yet released a fix?
