Cajun Jamie
- Joined
- Jan 31, 2019
- Posts
- 80
- Reaction score
- 39
LED bulbs only work one way. Did you try flipping them around? Also on the sockets--have you checked Dorman? I know they make replacement everything.before heading to the parts yard, any good source for running light sockets? Pulled mine both looked brown and burned on the inside. I don't mind cutting and splicing in replacements. I bought new LED running lights but neither side worked. PO must have just ignored them. Thanks!
View attachment 216114 View attachment 216115
Actually I did not flip them. I'll check that. Thanks!LED bulbs only work one way. Did you try flipping them around? Also on the sockets--have you checked Dorman? I know they make replacement everything.
Found them online for about $12 each if needed. Thanks!LED bulbs only work one way. Did you try flipping them around? Also on the sockets--have you checked Dorman? I know they make replacement everything.
Make sure the led light is the 4114LL style not 3157. I made what mistake before .
Another option is to delete the drl socket all together and splice another 3157 socket along with the original 3157 socket to create two signal bulbs instead of one.
