Roof rack cross bars
rpearlberg
I'm about to install mine, not for any particular reason but just because. What distance does everyone use from the front or back or the side bars?
DenaliCountry
I used the GM guidance from the instructions to place the front bar (15" from the front?) and then I measured my cargo box to make sure it was centered on the front and rear bars and placed it accordingly. If you would like I can measure them when I head outside here in a little bit.
R
rpearlberg
Sure, thanks. Don't go to too much trouble though. I'm not planning to put anything up there anytime soon, I just want to install them!
atwardowski
The instructions that come with the GM ones say 18" from front and back. If you have a cargo box/carrier they need to be adjusted accordingly. It also says if you have a sunroof and are using a box set the front at 30" (if I remember right), and the back about 27" away from the front bars.
btheboyscout
