RESOLVED - The 6.2L Dilemma: To invest in new shoes/shocks, or pull the plug? (Advice needed from the pros)
Sundancer
Army Law Enforcement
Long Island, NY
Hello everyone, I hope anyone currently affected by this Nor’easter is staying safe and hasn’t suffered too much damage over the last three days. Down here in Nassau County, Long Island, we’ve seen some massive flooding near the water. I’m lucky enough to be about 2.7 miles inland from the ocean, and knock on wood, I haven’t had any issues in the 25 years I’ve lived here.
I’m reaching out today to tap into the massive wealth of knowledge on this forum for an issue I know has been discussed here a million times. To be completely honest, I have very little knowledge when it comes to complicated mechanical stuff. I can detail the crap out of paint and make it shine like a diamond, but I rely heavily on YouTube and you guys whenever a mechanical issue pops up. So please, be gentle! Lol
Here is my situation: I have a 2020 Black Chevrolet Tahoe RST with a 6.2L engine, currently sitting at 62,650 miles. Visually, it looks like it just rolled off the showroom floor because I keep it pristine. Mechanically, everything is still stock original, serviced as need be but it is now in need of 4 new shocks (magnaride) and new tires (285-45-22). I do NO towing of a boat/trailer or carrying heavy cargo, and I use it primarily as a daily commuter under 20 miles a day and family road-trip vehicle? It has this tire size on it: 285-45-22 Bridgestone Dueler but looking at the Michelin Defender LTX M/S 2 .
Because I’m staring down the barrel of this major service expense, I’m stuck in a massive dilemma. Back at 48K miles, my fuel injectors and fuel rails had to be replaced at the dealership—which was nearly a $5,000 job. Ever since then, I keep reading about the lifter, engine, and transmission failure trends with these 6.2L motors, and I absolutely do not want to live through another major breakdown.
I've been a loyal Tahoe owner since 1999, driving various trims from LTs to my current RST. Frankly, I’m pretty disgusted with how GM has handled these engine issues. I love my truck, and I can't quite wrap my head around selling it just to buy a newer GM vehicle as it seems they are all having issues. At the same time, I'm wondering if I should just buy an AFM/DFM disabler, put the new tires and shocks on it, and keep praying. It's incredibly frustrating to feel like I'm driving a ticking time bomb. (I have looked at the Boost and Ranger models)
Should I invest the money to refresh the suspension and tires on a truck I love, or is it time to cut my losses before the 6.2L gives me real heartbreak? Any advice, thoughts, or experiences with the AFM disablers on these 2020s would be greatly appreciated. (I have looked at the Boost and Ranger models)
Thanks in advance, everyone!
ReaperHWK
Tires and shocks aren’t a problem. Normal wear.
The problem is the dealer service costs. You can buy the mag shocks (all 4) for around $1000 and DIY honestly, plenty of info online how to change them out.
I can’t believe those crooks charged you 5k for injectors. Holy smokes. I got a new transmission on my old truck for that price!
If it were me I’d do the tires and replace the shocks myself when I had a good weekend.
Or find an independent shop that would be half the cost of the dealer….
LEsoftballdad
Suffolk County, NY
Hi from Suffolk.
You have the L86, not the L87, which has AFM, not DFM. It's a slightly more reliable engine, but it still has lifter failure issues. Unfortunately, you're out of warranty, so any repair will be out of pocket and possibly expensive.
Get the disabler if you're going to keep it a year or two. If you want to drive it into the ground, do a full DOD delete. Your vehicle is now in its seventh year, and this is the time the annoying things start going wrong. Some people will drive theirs for 150-200K relatively issue-free, but it sounds like yours is starting to have nagging issues, tires aside. The good thing is that it's paid for, so even more expensive items are cheaper than buying a new one for $90K with the L87 garbage.
CMoore711
Yeah you posted in the 2021+ Section, but in fact your Tahoe is a 2020. All the recalls and issues with the 6.2L are with the L87 6.2L which is what all the 2021+ GM SUV's are equipped with that have the 6.2L engine.
Your 2020 Tahoe 6.2L is an L86 which although does have AFM (not DFM) is not a part of the same engine recall as the 2021+ models. That Tahoe RST performance with the 6.2L L86 and 10-Speed transmission is a great drivetrain.
It's honestly a dice roll rather you will ever experience a premature AFM lifter failure.
My previous 2015 Yukon XL Denali with 6.2L L86 (Same engine as your Tahoe)
I bought it CPO w/ 27K miles, installed a Range AFM disabler at 35K miles, changed oil every 4K miles, had AFM lifter failure at 78K miles. That was 35K miles with AFM active, and 43K miles with the Range disabler installed and consistent oil changes. Luckily it was still under the GM Powertrain warranty and the repair was covered.
Other owners maintain their vehicles all the same and never have an AFM lifter failure, many owners on this site are pushing a ton of miles without every using any AFM disabler device and have zero AFM related mechanical failures. So when I say it's a dice roll I mean it...
At 62K miles your rig has a lot of life left in it. I would spend the coin on the all new OEM shocks and struts and new tires. At this mileage if you haven't already done it once I would also add drivetrain fluids to your maintenance list.
Front differential
Rear differential
Transfer case
Transmission fluid and filter service.
If you don't want to do the shocks and struts yourself I would still buy your OEM shocks and struts from Rockauto and find a local independent dealer that will install customer supplied shocks and struts. You'll save SIGNIFICANT dollars over what any dealership is going to charge you for parts and labor.
Sundancer
Sundancer
Long Island, NY
I don’t believe yours falls into the 6.2 problem category. Those engines came after yours. I would do the maintenance, tune out the afm/dfm, and keep enjoying the vehicle.
Honestly the 6.2L has been having issues as a whole since 2020. The Feds just started looking into them recently and have gone back all the way to 2021. They are actively looking into the 2020 6.2L but have not made a determination yet. It is important to make a claim to the National Highway Administration because if they don't know, NO one knows.
Sundancer
Sundancer
Long Island, NY
Front differential
Rear differential
Transfer case
thanks for the advice. DOes anyone have a discount code for Rockauto. Any recommendations on an AFM disabler ?
Fless
Moderator
People's Republic of Colorado
You have over 60k miles on it; don't fret about the engine issue that are plaguing later models. Do regular maintenance.
The search function will show the link below for the Rock Auto discount codes. Just navigate to the latest (unexpired) code.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Keep it. My 2020 RST was traded in at 120k miles. I loved it, but no longer feel the pain of $100+ per fillip! I drive an EV now, but loved the RST!
"I'm wondering if I should just buy an AFM/DFM disabler, put the new tires and shocks on it, and keep praying."
You've answered your own question. Your truck has LOW mileage, and looks to be in pristine condition. To me, the answer is a no brainer. Keep it.
Find yourself a quality local repair shop, and start using them for jobs that you can't/don't want to do, and you will save thousands of dollars, versus going to the dealer. Use GM parts for any replacements.
You will really like the Michelin Defender tires.
Folks were will advise you regarding which AFM disabler you should purchase.
LEsoftballdad
Suffolk County, NY
The Range Disabler worked great for me on my 21 Sierra, but the lifters still collapsed. I understand mine were from a bad batch of parts, but who can say for certain? Another added benefit is that it disables Auto Start/Stop, too. They advise removing it from the OBD port if the truck sits unused for a week or more so you don't drain the battery.
Sundancer
Sundancer
Long Island, NY
The majority of the folks here strongly recommend that I keep the truck since it has LOW mileage. I usually don't have any issues making command decisions but what gets in the way is that I love the feel and look of this truck. In regards to the mag shocks, do you have any recommendations as everything I look at is over $1400.
B-train
that is what I keep telling myself but then on the other shoulder is that other guy saying " Dump it" :)
Well, if you decide to dump it, let me know what trade in value is. My 2017 Denali is at 190k all original, but adding a low mileage steed to the stable would be fine if the price is right.
Read between the lines: KEEP it, do good maintenance, and it will last.
Otherwise defer to paragraph 1.
Post the last 8 digits of your VIN, and @915_Tahoe should be able to provide you with the part numbers for the 4 Magneride shocks. Then, you can price shop at the dealer, RockAuto.com, and GMPartsDirect.com.
If you do any wrenching, you can replace the rear shocks yourself, without jacking up the truck. For the front struts, you will need to jack up the truck on jack stands to remove the struts, but the removal is easy. Then, I recommend that you take the existing struts and the new front shocks to a local repair shop and have them disassemble the strut, replace the shock, and reassemble the strut (~$100). Then, you can reinstall the assembles strut.
There are YouTube videos available to describe the entire process, step by step.
Sundancer
Sundancer
Long Island, NY
LR135822
alexblagoev
