Replacing fuel lines, mounting brackets
04BlackTahoe
Wisconsin
I have a 04 Z71, I had to drop the fuel tank to replace the fuel pump, in the process I decided to replace the steel fuel lines (last year I did the brake lines as they must have been as thickness as a piece of kleenex, and I imagine the fuel lines are the same). I got the tank out with no problem, I have the fuel lines disconnected on the engine, and the bracket that holds the 2 lines and fuel filter out. I am hoping to pull all 3 lines down at once and shove the new ones in. The lines I am guessing run up along the transmission but I am having a tough time seeing any brackets or where they are mounted.
Any help, tips, tricks, is greatly appreciated.
Mike
koomie98
