Replacing 5.7 Vortec Engine To Denali 6.2 Engine
Silver Yukon
Good day every one
I've got a 1997 GMC Yukon SLT 4WD with the original Engine. And also I have a 2008 yukon Denali which I made an accident with it few years ago. So now I'm thinking to take the Denali engine and put it to the old guy. I want to know what do I need to that. I think the hardest thing is how to fix the ECU. And because the Denali got an electrical throttle which throttle should I put.
Donnie Yukonie
Yates Caretaker
Im tuned into this one , Just got word of a friend that has a 6.2 in his garage he has no plans for , now if only i can scape up a couple hundred dollars without the wife noticing haha,
IMO I would keep the cabled throttle vs electrical. but I guess I'm just old school, However I have no idea how easy or hard the swap would be if even possible. I hope some of the engine swap gurus get in here and start a good discussion . Im subs
S
Silver Yukon
Thats why I want to do it now before I get married next year :fc5716bd:
I'd choose the cabled one too I think its much easier to fix.
Gzes
the drifting 2dr
Wichita tx
Yea cable is way easier. Electronic is not a good design imo. Kiss keep it stupid simple
97Tahoe2d4x
SF Bay Area
Use everything from the '08 engine/trans and PCM including drive by wire throttle since you have complete donor vehicle.
I've read some times mixing and matching gas pedal assembly/module between years/models could be a nightmare but you won't have that problem.
There are LSx swap parts and info on the net.
Good luck with your project.
livingez_123
Sandy, OR
You can get the engine mount plates from summit, take the entire harness and pear it down to what is needed for the engine and trans. It's a real easy swap. and if your not shy about electronics that will be easy too.
jbuck07
texas
How is the swap going? This seems pretty interesting....
Sent from my iPad using Tapatalk HD
Billy Buzzard
