Repeating fuel pump failure
Discussion in 'Engine & Drivetrain' started by singletrackboy, Jul 11, 2018.
  1. singletrackboy
    singletrackboy TYF Newbie
    13
    Oct 12, 2013
    Colorado
    Name:
    Brian
    I just can’t figure this out. I’ve replaced the fuel pump 4 times now in 8 months. I’ve done the job twice, I’ve had two different shops replace the pump as well. Every time a new filter and this last one, which was installed 2 weeks ago by a local shop, they said the tank was cleaned and should be fine. It ran great, until it failed again yesterday. Each time it was blamed on “a bad pump” but how can his keep happening?! ACDelco and Delphi. Any tips? I can’t just keep pouring money at this same problem over and over.
  2. YAMBAG
    YAMBAG Member
    46
    Aug 3, 2009
    westport MA
    Name:
    BRAD
    Have you checked the voltage at the pump? An under powered pump will not last long. Check the output voltage at the relay. Check it at the rear near the tank as well.
  3. swathdiver
    swathdiver Full Access Member
    4,936
    3,262
    Name:
    James
    Yes, you've got to check for a restriction in the fuel line that would strain the pump and more importantly as Brad mentioned, check the voltage against what it is supposed to be. Also, examine how the pump is wired up and made sure it is done right.
    bigfootchiro likes this.
  4. Doubeleive
    Doubeleive Elite Member Supporting Member
    3,582
    2,104
    Name:
    I understand it's a pain, but..... if you have the dealer replace the pump it is considered a "mr goodwrench" service and then falls under a lifetime warranty, nationwide. same for water pumps and a few other limited items.
  5. RED TAHOE LS
    RED TAHOE LS Full Access Member
    77
    664
    283
    Jan 2, 2017
    Monroe Georgia USA
    Name:
    David
    Whomever is replacing the pump, warranty should be included. You mentioned the last time (after tank cleaning) it was fine for a time then it happened again, looks like you found your problem. Sounds to me like trash in the fuel tank, get yourself another tank ( used ok) just take it yourself to radiator shop and have them put in their tank and clean, DON'T TAKE SOMEONE'S WORD.
    . Just had my 2nd one replaced, it lasted five (5) years and around 40k miles(AC Delco
    bigfootchiro and swathdiver like this.
  6. Doubeleive
    3,582
    2,104
    Name:
    unless you get it done by someone that offers PARTS & LABOR warranty then your only going to be covered for the pump, labor is still charged and these shop's like to sock it to you for dropping the tank even though it's not that hard.
  7. TARDIS
    TARDIS Member Supporting Member
    54
    53
    May 20, 2018
    Jersey Shore
    Name:
    Matt
    Complex problem usually with multiple points of failure.
    1) Gas tank can take on a leak (usually by the sending unit)
    2) Gas tank has water or sludge
    3) Low Voltage at the fuel pump
    4) It's almost always a loose ground
    Hope this helps
  8. bigfootchiro
    bigfootchiro Full Access Member
    668
    477
    Jan 31, 2017
    West Palm Beach, FL
    Name:
    Nathan
    I second ground. Exactly what I was thinking.
    TARDIS likes this.
Share This Page
